Home › Forums › Product Discussion & Questions › BeoMaster › Access OPTIONS on Beomaster 7000 › Reply To: Access OPTIONS on Beomaster 7000
12 August 2025 at 15:28
#68737
What sort of TV do you have? And what is the connection between TV and BM7000? Check that the cables are all fully inserted.
Assuming that TV and BM7000 are correctly connected, and the Pentas are connected to the TV, then the TV should be in V.OPT 2 and the BM7000 in A.OPT 0.
Using the BL1000, in the main room, with the system at stand-by:
Press SOUND then 0 then STORE (to put the BM7000 in A.OPT 0)
Press PICTURE then 0 then STORE (to put the TV in V.OPT 2) EDIT: See below: Should read PICTURE 2 STORE
