Home Forums Product Discussion & Questions BeoCom Beocom 6000 +PTSN Caller ID over VOIP Reply To: Beocom 6000 +PTSN Caller ID over VOIP
#65412
Hi Guy, many thanks for your response.
I’m not sure which version of PTSN it is, so I have a ttached a photo of the back of it, hoping that will identify it.
I have 3 Mk1 6000s and 1 Mk2. The Mk2 was a big help in opening the beoline for registrations  rather than interupting the power all the time.
When I first registered all the handsets, I noticed that there were still 3 handsets registered to the base, none of which were in my possession. I did manage to remove all these, although I thought that would be impossible as I didn’t have them!
The actions of setting the 4 handsets up  also included a reset on each Mk1  handset with the dot 7 000 9 sequence. Iwill try starting again, though, to see if that gives me the result I would like.
Many thanks,
Keith
