Home › Forums › General Discussion & Questions › General Discussion & Questions › Playmaker mk. 1 configuration issues › Reply To: Playmaker mk. 1 configuration issues
22 April 2025 at 19:38
#65282
Hi Alls,
My two cents expertise…
If you do drag, like me, and old setup, using it to the bones, meaning old Ios, Old MacOS, and old 2.4 Ghz wifi, you should be fine.
If not, given your wifi is 2.4 compatible, the integrated web server should make it. There is no bonus trying to use the B&O App, it is just useless.
So set it up with the web server and forget it.
