Home › Forums › General Discussion & Questions › General Discussion & Questions › Playmaker mk. 1 configuration issues › Reply To: Playmaker mk. 1 configuration issues
I just tried to do a factory reset of my MK2 Playmaker to refresh my memory of the setup proces.
Initially I tried to use the B&O app for setup. But if I add a new product and choose Playmaker the B&O app says to go to wireless settings and choose the wireless network with Playmaker in it’s name. If I do that and go back to the app I still get the same message. I can see this is also the case for Beolit 12 which I belive is based on the same platform.
So I guees the app is not fully updated for setup of these products anymore.
Instead of the app I tried to go to the setup webpage mentioned in the manual
http://169.254.11.22/ But had no luck getting there. I tried with an IP scanner on my phone to find the correct IP and it turns out it was http://192.168.1.1
(I am not sure why this is not as mentioned in the manual, but maybe a difference between MK1 and MK2 or something that has changed with an software update.)
from the setuppage I could setup the Playmaker to use my wireless network and it is now active again.
hope this is helpfull for setup of a playmaker
