Home Forums Product Discussion & Questions BeoLink Powerlink Comptability Reply To: Powerlink Comptability
#64421
Guy
“\nGuy wrote:\nI am leaving the Essence\/Passive set up for a few days to see if I experience any longer term problems using a fully wired RJ45 to PL lead.\nGreat, then we can see if the long term issue that Steve mentioned in that other thread do apply in your case”
I have had to pack the equipment away again today, but in the two weeks that the Essence Mk2 has been set up, the standard, fully-wired RJ45 to PL cable worked perfectly to turn the Passive on and off at the appropriate times.  There is a delay after using Bluetooth, but this is expected because the Essence waits a while (by design) to send the power-off signal over the PL socket.  At random times (pre- and post- shutdown) I checked the voltages at RJ45 pins 4&5 and they were identical.
For the last week or so I added my Beoplay M3 to the mix to see if additional NL devices had any effect, but there was no change to behaviour.   I didn’t add the NL/ML Converter (or any ML devices) to the test, so that is one thing that could potentially affect the Essence/PL behaviour, but I doubt it would make any difference.
