Home › Forums › Product Discussion & Questions › BeoLink › Beolink PC2/Beoport & BeoPlayer › Reply To: Beolink PC2/Beoport & BeoPlayer
I have Beoplayer and Beotray in my start up apps and it starts it up and is then always available via the right hand side of the screen. Didn’t work well under Windows 10, had to authorise the app every time.
I suspected a display compatibility problem with the laptop – especially as it has a touchscreen. I therefore connected the Win11 laptop to my PC’s 26inch Dell monitor and the Beoport control panel now appears on the right hand side as normal, including showing the ‘HOLD’ button.
Hence I would have no hesitation in installing Beoport/Beoplink PC2 on a Windows 11 PC in the future. (The only limitation is the strange muting on change of N RADIO channel, which has been a problem since Win7)
