Home Forums Product Discussion & Questions BeoSound Beosound 4 and 5 together? Reply To: Beosound 4 and 5 together?
#57133
Guy
One annoying thing though โ€“ the Beo4 does not seem to have โ€˜L-A.Auxโ€™ available as an extra button, so I would not be able to select that source using my Beo4 on my Beolab 3500.ย  It has L-V.Aux but not L-A.Aux.ย  What a strange omission!
If using link commands (L-etc) frequently, you could put a Beo4 in permanent link mode and then simply use A.AUX.
To set in permanent LINK mode:
  • Standby + List together
  • Press List till CONFIG appears
  • Enter 2002, the display should read LINK ON
  • Press Exit
Repeat the above process to return the Beo4 to normal mode.
EDIT:ย  The later Beo4 NAVI (with the little joystick) may well have L-A.AUX as an option – it is listed in the Lexicon.
My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
