Home › Forums › Product Discussion & Questions › BeoLink › MCL 2AV Power Adapter › Reply To: MCL 2AV Power Adapter
28 June 2024 at 11:26
#57089
GOLD Member
Ag good – at least I have an alternative then. If I can’t get an MCL2P I’ll get a Beolink Passive and an IR Eye, and connect it to my ML Distributor. The Beolink Passive amps come up cheap on eBay sometimes, but the IR Eye demands a much higher price. I have occasionally seen them sold as a package through (a 1657 with an IR Eye) so I might look out for that.
It is possible to hook up another type of IR eye to it like the MCL type. You will loose the volume control functionality on it though
