Home › Forums › Product Discussion & Questions › BeoVision › Beovision 7-40 Mk5 – 3D capability? › Reply To: Beovision 7-40 Mk5 – 3D capability?
8 June 2024 at 07:52
#56359
As far as Iโm aware the BV 40 Mk 6 is the only version to have the 3D capability.I believe the panel in that version is shared with the BV11-40 that I have. If the entries are shaded out, then that usually means that they anrenโt available to you to make use of.
