Home › Forums › Product Discussion & Questions › BeoLab › Beolab 5. When you need help with your ICE module › Reply To: Beolab 5. When you need help with your ICE module
7 June 2024 at 13:23
#56347
GOLD Member
Hi @beobuddy,
Speaker type is 6881 with SW 2.6 (not sure which revision of speakers this is mk1, mk2 or mk3).
Yes, speaker stop responding to remote controller commands once it gets warm (after 1..3 hours of normal operation – no loud audio there).
I can certainly check if micro is covered with something but how do you draw any conclusions out of it?
How would you go about fixing something like that? Do you offer service to fix it?
Thanks,
Henryk
