Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3500 and Beocenter 8500 – possible? › Reply To: Beolab 3500 and Beocenter 8500 – possible?
I’m not sure what it will actually do when connected,
Put simply, it will allow you to play the TV audio through the BC8500, and vice versa.
This is dependent on ‘Option Settings’. If TV and BC are in V.OPT 1 and A.OPT 1 respectively, each will normally play sound though their own speakers and be controlled directly by the Beo4. In this setup, if you press ‘AV’ before selecting a source, if will play through the ‘other device’ – i.e TV will play audio through BC8500 speakers (if connected) and BC8500 will play through TV.
Other option settings will change the behaviour, but it’s probably best to come back and ask once you have it setup!
