Home › Forums › Product Discussion & Questions › BeoLink › BeoLink Gateway setup help › Reply To: BeoLink Gateway setup help
14 April 2024 at 05:35
#54248
Second thought >
if the Beolink NL|ML Converter (BLC) is setup correctly and you give the set IR command to start the B&o radio to the BV7 then the radio should play on the tv.
so could you post the BLC settings.
