Home › Forums › Product Discussion & Questions › BeoTime › Beotime battery access › Reply To: Beotime battery access
11 April 2024 at 18:39
#54220
That’s the plastic battery tray that holds the 3 batteries. If you turn the Bedtime upside down and tap it against your hand it should slide down, a few more gentle taps on the side and you should be able to remove it.
