BeoWorld Logo
Home Forums Product Discussion & Questions BeoCenter Beocenter 9500: problem with Line-In/Line-Out port Reply To: Beocenter 9500: problem with Line-In/Line-Out port
#54177
AdamS
GOLD Member
    The Line In/Line out connector is to separate the preamplifier and power amplifier sections of the unit and is not suitable for plugging anything external in. As you have found, if you remove the linking plug, you don’t get any sound from the speakers.
    I can’t comment on where the 36mV figure in the service manual came from but it sounds like a misprint! the Tape 2 and AUX connections are normal line level inputs and so this is where you should be connecting your streamer.
