Home Forums General Discussion & Questions LG update to newer WebOS – question? Reply To: LG update to newer WebOS – question?
#54104
Sandyb
    Guess its the same as when you first setup a BST/LG from new.
    i.e. the B&O app page for the BST has the “Enable LG/B&O app integration” type banner / message.
    The difference (compared to box fresh and new) was that my LG already had the B&O webOS app installed. So, what to do?
    I forced the issue a bit, by deleting the webOS app and re-installing it.  The B&O app says to restart the TV when the app is installed, which I did but “integration” didnt take hold / re-establish itself.  I went round this loop a couple of times, and  then just rebooted the Theatre, which seemed to re-establish the integration.
    I guess, once the integration had disappeared initially, I should have perhaps just rebooted the Theatre. Not sure deleting/re-installing the B&O webOS app process was necessary – but who knows.
    Anyway, all good now.
