Home Forums General Discussion & Questions General Discussion & Questions LG update to newer WebOS – question? Reply To: LG update to newer WebOS – question?
#54102
Sandyb
Just to add….while I did update both my rooms to the new webOS, I hadn’t used my main living room Theatre/LG setup after updating.
While my standalone bedroom Theatre/LG was fine with the new webOS, my living room setup seemed to lose the LG integration – example being all the internal sources were gone from the BR1 etc etc.
So I had to re-establish the LG/B&O webOS integration – which was a bit of a messy process, took a few attempts, but back to normal now.
Bit odd, I only had to do this on one of my Theatre setups.
