Home › Forums › Product Discussion & Questions › BeoCenter › Opening up a Beocenter 8000 › Reply To: Opening up a Beocenter 8000
7 April 2024 at 10:48
#54050
GOLD Member
There’s any easy way to identify the cassette deck by looking at the screws; it’s the version 2 cassette deck of the 8000 thru 9500 range, but it may be that the 8000 specifically only ever had the version 2 cassette deck.
The CD and cassette doors seem to work fine but I see your point auric – the belts are cheap so I will order them and replace them while I’ve got the thing open.
Thanks everyone for you help – once those tape belts arrive I’m confident I can get the thing in full working order.
