Reply To: Opening up a Beocenter 8000
Home Forums Product Discussion & Questions BeoCenter Opening up a Beocenter 8000 Reply To: Opening up a Beocenter 8000
#54049
auric
    • Topics Started 15
    • Total Posts 87
    There may have been two different versions of cassette mechanisms for the BC 8000… This was the case with later versions as the series evolved.
    The two mechanisms have different belt configurations. beoparts-shop.com has the right belts and parts including the pinch rollers! Check with them.
    While you have the unit open, you may as well change the belts for the doors as well since they are quite old by now.
