Reply To: XTRA Speaker and MCL Issue
Home Forums General Discussion & Questions XTRA Speaker and MCL Issue Reply To: XTRA Speaker and MCL Issue
#53879
ICHooligan
    • Indiana, PA, USA
    • Topics Started 1
    • Total Posts 14
    Ok, so I do have an additional question or two. Same set-up here, MCL2AV in garage, running wires up to XTRA speakers and an IR Eye that is run off the B&O 1000 remote control. I noticed that the sound is a lot lower running off the TV with a bluetooth receiver and the sound only goees up to 78 when controlling the IR eye with the remote and honestly, 78 is not that loud, however, if I was running the main system radio onto these speakers, 78 would probably break the windows. Does anyone have any suggestions or comments as to why it would be lower using it this way or why the speakers will only go up to 78 when controlled with the remote and the bluetooth receiver that is attached in the garage to the MCL2AV through the TV port with a 7 DIN connector that has 35mm jack on the opposite end going into the bluetooth receiver?
