Home › Forums › Product Discussion & Questions › BeoVision › Beovision 10- PC HDMI Connection › Reply To: Beovision 10- PC HDMI Connection
Hi Bax24
Congrats on ‘your new’ tv.
It is definitely a hotel version of the BV10.
This means that it has a modified sw – if and how this can be changed to the regular sw, I will let others advice on….just wait and watch if other users here can comment.
Meanwhile you can try, if you can access the main menu of the tv (use the Menu button for that) – let us know if and how that looks on the screen!
Generally you must – with a BV – assign the (HDMI) input, that you are using, to a specific source button on the remote in the settings menu for easy access.
However this might be impossible with the remote that you have.
If you can get hold on another regular remote version – either a Beoremote One or (even better) one of the newer Beo4 versions – it might be easier to do.
In any case – if the sw can be changed – you will need one of those.
N.B.
Do not sell or throw away the one you already have, it might be a collectors item.
You can find the guides for the regular/original versions of the BV10 here
