Home › Forums › Product Discussion & Questions › BeoRemote › Beo5 & Beo6 › beo5/6 adaptor part › Reply To: beo5/6 adaptor part
Yes it is a two part construction: a hard plastic part with a rubber “sock”.
If the rubber sock only is torn, you can replace it with a flat rubber ring (plumbing).
If the hard plastic part is broker yes it can be more difficult. Then I need to see how complicated would be to design the mesh, given one could add the electric contacts. Maybe not that easy.
If your solution did work (the tape) that would not be difficult to design a sticker and print it in thick vinyl. It happens I do have a plotter for that kind of thing and can try this for you.
In the meantime you can cut a piece of vinyl, apply it on the base, rub it with your finger and then follow the crease with the tip of an X-acto. That would give you a perfect shaped base.
Hope this helps.
