Reply To: Beovision 6 26 Pincode menu not showing
Home Forums Product Discussion & Questions BeoVision Beovision 6 26 Pincode menu not showing Reply To: Beovision 6 26 Pincode menu not showing
#53563
muppets4
    • Topics Started 1
    • Total Posts 2
    Thanks.
    Unfortunatly it doesn’t solve the pin situation. Right after clicking STOP I am at the snowscreen again.
    I am missing the tuning option in the menu. On the other TV’s I programmed the AV under the channel numbers. I did select DECORDER under connections for AV1 and AV2, but can’t program them while missing TUNING. But maybe that has to do with the PIN situation?
    EDIT: I solved this by going into the TV with the Master Code 11111 and then with 0 0 and go to enter the system menu and reset to factory settings. Strangely I got back the option for TUNING.
