Home Forums Product Discussion & Questions BeoConnect Beoconnect Core with HDMI (e)ARC Reply To: Beoconnect Core with HDMI (e)ARC
#53470
beojeff
Perhaps you thought I was asking for your advice? I wasn’t.
I suspect that the tv’s internal speaker could be used for the center channel. Such a speaker could hardly keep up with the quality of beolabs, though.
This will not be possible and even if, a really bad idea soundwise. These internal speakers would still be a set of L/R speakers and there would be no option to adjust for level matching or for setting up speakers distance etc. Personally – if I would need a non-B&O tv for the kitchen – I’d still go for a Stage, despite it being a bit older now and not a Mozart platform device. IMO, if you go for a 2 channel setup for a tv, you should place the speakers on either side very close to the screen in order to maximize the illusion of a phantom center. How about a set of the BL12’s ? if you use a tv as a computer monitor, you can get away with a 2 channel setup, since you probably are the only person and you are sitting right in front of the screen. MM
