Home › Forums › Product Discussion & Questions › BeoRemote › Beo5 & Beo6 › Beo5 & Beo6 Software (Firmware) versions › Reply To: Beo5 & Beo6 Software (Firmware) versions
15 March 2024 at 22:52
#53381
With the Beocom 6000 there is an A and V button that you press before using the wheel to change the volume.
I did notice how the dealer was careful to distract viewers from the delay on the screen. But why? No other remote was doing it at the time anyway, so no one was faster.
My fat sausage fingers would be a problem with those small keys. You could probably make them bigger in the configuration tool but that would mean spreading them over more screens, so you’ll need to consider if that is better for you.
Stoobie
