Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab 18 + Beolab 19 setup using Beosound Core › Reply To: Beolab 18 + Beolab 19 setup using Beosound Core
#53357
DT79
That’s true of daisy-chaining via Powerlink, but if you use a Transmitter 1, that does include bass management, right?
I really wish B&O would release a new ‘Core; which is Wisa enabled itself, includes bass management like the Transmitter 1, has a wider range of inputs and also has the Active Room Compensation built in. Although they’d probably charge about £10K for it knowing them! I know there are ways of achieving the same through 3rd party kit (I’ve got it), but it’s crying out for one elegant device within the B&O ecosystem.
This is possible but there will be no bass management in terms of crossover frequency. Both speakers will play full range. You’ll have to manually adjust the BL19 to get it to “meld” nicely with the 18s.
