Home Forums Product Discussion & Questions BeoPlay Beoplay V1 not turning on Reply To: Beoplay V1 not turning on
#53052
alexsalles
Im having the same issue with my V1. I noticed there are some voltage written on black thin plastic label around it. and suddenly that come apart and they look like two batteries.
I tried to remove the soldering that was holding the clip and I ended up getting the whole clip off the board.
Anyone has an idea how to remove the clip from the battery and which kind of battery will fit here? they dont seem to have anything written on it apart from some voltage and amperage on the plastic label.
is it two batteries or the lower one is is the actual battery and the top part is a holder that got rusted on it and made them too stuck together?IMG_7695IMG_7698IMG_7694IMG_7693
