Home › Forums › Product Discussion & Questions › BeoVision › Beovision 10 and new Apple TV › Reply To: Beovision 10 and new Apple TV
Im Going back many years but from me memory you would need to use optical to rca from the Apple TV and I wouid presume use the scart socket, might be able to use spdif socket, then the masterlink will carry the sound to the link rooms, passive kits shoud work ok link room you would need to press the av command followed by source ie dtv. That worked on the avant and bvis 7’s I think that will work on bvis 10
Yes that all makes sense and should be the same on BV10. Pressing AV before DTV is only required if the link room is in L.OPT 5 (where it normally only responds to audio commands). If you put a Link Room in L.OPT 6 it should respond to both audio and video commands, hence no need to press AV first.
