Home › Forums › Product Discussion & Questions › BeoLink › Compatible replacements for MCL 2 Expander Type 2008 › Reply To: Compatible replacements for MCL 2 Expander Type 2008
The MCL 2ABLI and MCL 2AV are both compatible with other MCL 2 equipment.
However non of them will work as replacements for the MCL2 Expander as they do not have the circitry for amplifiying the data signal and supplying power to the MCL units after the expander.
If you are not able to find a expander replacement you could look into alternative options depending on how many link rooms you have and how easy it is to do new cabling in your home.
The BM5500 can be connected to Masterlink link room products with the addition of a Beolink Converter 1611 or 1612
