Home Forums Product Discussion & Questions BeoApp How do you live with the Bang & Olufsen app and the music? Reply To: How do you live with the Bang & Olufsen app and the music?
#51110
Millemissen
    The iPad that I permanently had in my main living room on a stand was getting lame and old.
    So I though I would replace it like I did in the kitchen.
    This older iPhone sits on a Magsafe charger ready to be picked up, if needed…..for deeper searching of music.
    Mostly I just swipe up from the ‘Clocks screen’ to access the B&O app.
    Here are 3 pictures.
    1: When not in use
    2: When ready for being used – with my main apps at a glance
    3: When playing (on the Theatre set up in a 2 channel listening position for music).
    IMG_0813
