Home › Forums › Product Discussion & Questions › BeoMaster › BEOMASTER 5500 – Connecting a WiiM Pro Plus to Pre-Outs? › Reply To: BEOMASTER 5500 – Connecting a WiiM Pro Plus to Pre-Outs?
Good idea!
If I well understand your project, you plan to connect an output of the Beocenter to the line input of your Wiim in order to send the signal through an Apple Express to a pair of 6000s in another room.
Assuling that you control the volume of the 6000s through the Wiim app, so I would do as this:
Connect the 5500 tape2 out to Wiim line in (note that tape-out is fixed line-level).
In Wiim home app, select line input or maybe Line-in auto detect (I have not tested this).
Turn the volume of wiim to minimum to avoid a bad surprise, then chose your apple express as audio output interface.
Play a CD on the 5500, enjoy (I hope) and let me know 🙂
I have a Beocenter 9500 and will connect it’s tape2/out to the line-in of my Wiim Pro Plus.
It may enable me to distribute the phono and tape to the rest on my system (ML and NL products).
Kind regards,
Yann.
