Home › Forums › BeoWorld around the world! › North America › Eclipse sound ? › Reply To: Eclipse sound ?
#49934
Stan
I’ve seen Geoff Martin (B&O sound meister) mention that the BL2 doesn’t play nice with BL9/20 or any BL with strong low bass capabilities (BL28, BL50/90).  If I understand correctly, it has something to do with the slight delay from the BL2’s passive drivers cancelling out the similar bass frequencies from the other BeoLabs.  So.. if you run out of other ideas, turn off the BL2 and see if it helps… easy enough I would think.
