Reply To: Apple TV Siri remotes and IR Beovision
Home Forums Product Discussion & Questions BeoVision Apple TV Siri remotes and IR Beovision Reply To: Apple TV Siri remotes and IR Beovision
#49730
Guy
    • Warwickshire, UK
    • Topics Started 15
    • Total Posts 1,355
    I have just tested again after just over 12 hours of standby – all still working as before!
    One other thing that I forgot to mention.  I tried setting the Apple TV ‘delay before Apple TV automatically turns off’ to 5 minutes and left the system running.  After 5 minutes, the Apple TV does turn off but there is no ‘off’ message sent to the TV, so it stays on.  If it had switched off the TV then this would have been useful for turning off the ‘system’ after airplay ceases.  I suppose you can always set the TV to go to standby automatically instead – I can set the BV10-32 to do so after one hour.
    One other aside:  I bought a new bracket to mount this smaller 3rd gen ATV behind my TV and can recommend this one:  https://www.amazon.co.uk/dp/B0C4PQ7R32
