Home › Forums › Product Discussion & Questions › BeoApp › Bang & Olufsen App – Beta version 5.x.x. › Reply To: Bang & Olufsen App – Beta version 5.x.x.
Если вы полностью меняете свой маршрутизатор, например, отключаете старую сеть и продукты больше не могут к ней подключаться, они также автоматически перейдут в режим настройки сети после отключения питания.
Thank you for the detailed answer.
As far as I understood correctly, after disconnecting the router from the network, I also have to disconnect Beosound Emerge from the network and connect BE back to the network, then it will automatically switch to network setup mode, and where in the Application will I have to enter the password for the new network?
Will there be some window for me to see a new network and enter a password?
Or if to keep old the SSID and password for connecting to WI-FI the same in the new router, then the connection will also happen automatically?
