Home Forums Product Discussion & Questions BeoSound Beosound 3200 not sending data to speaker displays Reply To: Beosound 3200 not sending data to speaker displays
#46680
Guy
    Hi and welcome to Beoworld!
    Are you sure that the cables are not faulty? Have you tried swapping them out/around and/or trying both powerlink sockets?
    If you have a multimeter, check the continuity of the PL cables – pin 6 is data and pin 7 is data ground. Make sure that pin 6 isn’t shorted to one of the other connections.
    It’s also worth disconnecting anything else from the BeoSound (Masterlink and Aux socket) to rule those out as part of the problem.
    My B&O Icons: BeoCenter-9500 Beo4 Beovision-10BeotimeBeosoundBeosound-Explore Beosound-Essence Beoplay-P2Beoplay-M3Beoplay-H4Beoplay-H3Beoplay-Form-2iBeoplay-EarsetBeoplay-A2
