Home › Forums › Product Discussion & Questions › BeoLink › Max Input Voltage … setting recommendations › Reply To: Max Input Voltage … setting recommendations
#46580
NQVHNWI
XLR is very low impedance compared to RCA.
I think you are sweating it too much. The best way to connect your receiver via RCA is as per the method I listed above.  – downgrading the BL50 max volume until you are happy with the control. Then listen.
one extra complication….does your Reciever have RCA outputs? If it is XLR only, you may need to have passive XLR to RCA passive converter? Your Dealer should be able to help?
