Home Forums Product Discussion & Questions BeoLink Beolink Passive IR eye Reply To: Beolink Passive IR eye
#45800
Guy
In conclusion my BL Passive / Ml-MCL converter seems to work for all functions
Good conclusion – if I do try anything similar with the BC9500 as a source I’ll post it here, but it’s only really the ‘timer’ functionality (with rectangular sensor) that may be worth testing. I vaguely remember having problems trying my BC9500 with a BL1611 and Passive many years ago but can’t remember what sensor I used. Performance may be related to the SW version of the BC9500 source of course, so I’ll check the config tool to see if there are any relevant notes.
It may be worth deciding terminology/names when talking about IR eye/sensor types. I tend to think of the four main types as follows:
MCL sensor (normal rectangular type with Timer and Mute buttons – 5 connections hard wired)
VX sensor (as MCL but no buttons – 3 connections only to 3.5mm plug)
ML sensor (normal round type with Timer, Vol and Play button – 5 connections – usually via 7 pin DIN)
BS3 sensor (as ML but with no button markings – 5 connections possible but only three used to 3.5mm plug)
I haven’t mentioned newer ones with fancy ‘join’ buttons and RJ45 connections etc. Nor special hardwired types like the BM7000 sensor which will be a variation of the above (probably VX with DIN plug).
Next subject is my new NL/ML converter, and I probably will test the IR receiver with that also, but that’s for another thread
Looking forward to the new thread!  I expect experimentation with all the above sensor types and full MCL/ML/NL integration – just think of the number of permutations once you add in Converter configuration settings!! ?
PS:  It could be worth getting hold of some of these if you do want to try different sensors: https://www.amazon.co.uk/PENGLIN-Terminal-Ethernet-Extender-Connector/dp/B0BTYH9726
My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
