Home › Forums › Product Discussion & Questions › BeoLink › Beolink Passive IR eye › Reply To: Beolink Passive IR eye
16 April 2023 at 12:15
#45780
I think it’s worth a try with just ground, 5v and IR and I think it will work. I have had good results mixing IR sensor with just those connections: I have used both VX sensor (old rectangular shape) and a BS3 sensor (circular) with my Beoport, for instance. I also successfully connected both those sensors to a LC2 in place of the IR board and it worked.
With regard to the other two connections, maybe SCL to CLK and SDA to BUS? I would think there’s a low risk of damage (but equipment may lock up until power is recycled) but then it’s not my equipment!
Looking forward to hearing results!
