Home › Forums › Product Discussion & Questions › BeoLab › BL3500 and the MCL/PL connector › Reply To: BL3500 and the MCL/PL connector
7 April 2024 at 06:57
#44617
GOLD Member
On a beo4 with joystick you can select ‘mode’. There are 3 modes. With your ‘mode’ setting pressing the ‘play’ button instead of the joystick should do the trick.
Yes of course. Thanks for reminding me. I Did not think that far when I was trying to use it, and had the other BEO4 near by.
