Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 with 3x BeoLink Passive zone issues? › Reply To: Beosound 9000 with 3x BeoLink Passive zone issues?
9 February 2023 at 14:02
#43631
Hi and welcome to Beoworld!
Have you tried swapping the IR sensors between the two passives, to see if the fault follows?
I would suspect cabling of one of the IR eye’s to be either incorrect or disconnected, either inside the sensor itself, or inside the DIN connector.
