Home › Forums › Product Discussion & Questions › BeoGram › BG 5500 Arm string ankers broken › Reply To: BG 5500 Arm string ankers broken
7 April 2023 at 20:16
#43620
Thanks for your good suggestions. A simple bolt and nut worked perfectly as well. Just be careful while taking the two gliding elements out of the plastic fixtures to install the bolt. These could become brittle with age? Follow the instructions to reinstall the string properly thereafter and it works well!
