Home Forums Product Discussion & Questions BeoLink MCL2 AV no 5,5V Reply To: MCL2 AV no 5,5V
#43530
Guy
    Am I right in assuming that the MCL2 AV will start up and work stand alone without connection to a MCL master?
    Yes – I used to use one like that as a stand alone amp for my PC. It even gave two-way IR in stand-alone mode!
    Are you using the offical Power Supply, or the supply feed from an MCL2P? Mine worked with both.
    EDIT: I know you’d like to see my neat cabling …. ?
    DSC06672
