Reply To: Problem with NL/ML converter
Home Forums Product Discussion & Questions BeoLink Problem with NL/ML converter Reply To: Problem with NL/ML converter
#43360
LukeS
    • Topics Started 4
    • Total Posts 28
    The BLC itself seems a solid product – no complaints at all on mine. I primarily use it to link older MLC and ML equipment with modern NL beovisions. For this it works flawlessly and reliably once set up properly. There is a specific order you need to power things up, so if there is a power cut then you may need to re-initialise things. Aside from that no big problems if your main use case is controlling things with a BEO or beoremote one.
    I’ve had less positive experience with the app, but that isn’t my use case anyway, and others have said more recent versions of the app work better (I’ve not tried).
    in my honest view the BLC has been one of the best B&O products I’ve purchased over the years.Takes a bit of time to understand and configure but worth getting if you want to integrate older products in your setup.
