Home › Forums › Product Discussion & Questions › BeoLab › Streamer for Beolab 5 › Reply To: Streamer for Beolab 5
24 January 2023 at 17:07
#43180
The BS3 has no SPDIF out like the BV9.
Robin,
BV9 has no SPDIF out. This TV is in fact a Beosystem 3 packed with a plasma screen and a center loudspeaker.
If you refer to my schemes, the digital connection to BV9/AV2 is used to send the multichannel signal of Beocenter 2 to the internal processor of BS3 for DVD playback.
You could make a test without the SPDIF connection to AV5 and have a single connection between Node and BL5:
- Selecting AV5 on BS3 in order to control Volume with your remote,
- Direct SPDIF connection from Node to BL5 to feed it with the digital signal.
Kind regards,
Yann
