Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002 (5511) – turns on when it is turned off › Reply To: Beogram 4002 (5511) – turns on when it is turned off
23 September 2022 at 10:32
#39140
Thanks Mark.
I have now replaced all of the cylindrical capacitors – and actually also TR1. If the switch you’re mentioning is the on/off switch – I have cleaned it several times. Nothing has helped so far.
Concerning diode D1 – I think that what you write is according to and earlier version off the turntable (type 5501 or 5502). I have type 5511 – so I might have to look upon D5 instead (but I’m not sure because I don’t have the right version of the service manual).
BR Behsen
