Home › Forums › Product Discussion & Questions › BeoLab › Adding Beolab 11 to a pair of Beosound level › Reply To: Adding Beolab 11 to a pair of Beosound level
16 August 2022 at 21:34
#37020
Thank you both Hjort and Millemissen,
I’m getting a bit confused, So as a general question, if I for example stream music using B&O-app from a BS-core that is connected to Beolab 11, can BS-Levels be joined without delay? If there will be a delay in such a system, what would it be caused by? After all they are supposedly using the same sound source, or are they?
