Home Forums Product Discussion & Questions BeoPlay Beosound 5 settings Reply To: Beosound 5 settings
#34585
NQVHNWI
Im a bit rusty on BS5 settings with ML TVs. Hopefully this will give you pointers to self-diagnose.
  1. BeoSound 5 / Beomaster 5
    Connection Audio
    BeoSound 5 can be placed in a setup, where either BS9000, BC2, BC2AO,
    BS3200 or BS4 is used as audiomaster and BeoSound 5 is used
    for N.MUSIC and N.RADIO.
    Audiomaster YES/NO on BeoSound 5 must be set to NO in this setup.
    This will disable OPTIONS setting for the BeoSound 5.
    The OPTION setting, referred to in this conclusion refers to
    the Audiomaster.
    Selecting option on the audio master
    Option:  AUTO configurating (option 0)
    ********************* AUDIO/VIDEO/LINK SYSTEM SETUP *******************
    Connection
    Connect the Master Link socket of the audiomaster to the MASTER LINK
    socket of the TV-set using a BeoLink cable.
    ********************* REMOTE CONTROL FOR MAIN ROOM ********************
    The recommended remote control is Beo4
    The following remote controls may also be used:
    Beo5
    Setup for Beo4 remote control:
    Beo4’s “LIST” must contain the following items in order to be able
    to operate the Main Room products.
  2. You will not see the BS5 on the TV. However, you will get Beomaster5 contents on N.Music or N.Radio
  3. Connect Beolabs to the TV PL outputs and not the BS5
