Home Forums Product Discussion & Questions BeoCenter BeoCenter 9000 troubleshooting Reply To: BeoCenter 9000 troubleshooting
#34502
Guy
Very low audio: If I turn the BeoCenter all the way up, I get sound. At normal listening levels, I get nothing. I can hear a cassette and CD playing fine through speakers and headphones, but way too low. The fuses are all okay. The lights all work as expected as does the remote. Switching between outputs works fine. Any suggestions where to look or what to do next?
This could possibly be a mute relay problem – maybe search the archived forum for ‘mute relay’ and look at the results for both BC9500 and 9000. One quick way to check is to plug the speakers into the speaker 2 sockets as these are not wired though the relay. If this works, the relay is probably the problem, and is quite easy to replace.
