Home › Forums › Product Discussion & Questions › BeoCenter › how to select DVI on Beovision 6-22 › Reply To: how to select DVI on Beovision 6-22
1 May 2022 at 16:49
#34474
Maybe still worth seeing if your Beo4 has the later software – it needs version 3.4 or later.
Have you tried adding PC to LIST ? (Press Power and LIST together, then select ADD etc)
Otherwise best (only) option is to find a newer Beo4 or any BL1000.
