Home › Forums › Product Discussion & Questions › BeoSound › Beosound stage › Reply To: Beosound stage
16 April 2022 at 09:02
#34215
GOLD Member
Stage/C1 is a common combination – there should be no problems there.
You can use the line input of the Stage for any audio device….with the right cable.
However, if you connect the BM5 you will have to deal with two x volume controls (and maybe even two remotes).
Do you also have the BS5 unit?
If you just want to have access to the music on the harddrive of the BM5, you can access the files throught the Stage/the Bang & Olufsen app.
You also have access to internet radio via the Stage, no need to use the BM5(/BS5) for that.
But maybe you like the BM5(/BS5) and want to keep it —— it is possible, but with some drawbacks.
