Home › Forums › Product Discussion & Questions › BeoVision › BEOVISION 14 ANDROID › Reply To: BEOVISION 14 ANDROID
17 April 2024 at 02:12
#34039
Hi Lee, I am having a similar problem with my Avant NG. Unfortunately the 2 factor authentication solution is not an option with really old versions of Andriod. A possible solution is to sideload slightly newer versions of the Play Services, Chromecast (if applicable) and Youtube. It is a bit of a fiddly process and not always successful (I didn’t have luck). If you search BV Horizon – Cannot log into Google, on the forum you will see a similar issue.
